Visual composer bug
in Rife Posts: 127
Hi !
I have a problem with visual composer : the front end builder doesn't work, it doesn't show my slider, or background.
I was allready using visual composer and revolution slider with the previous template and it was ok.
Do you know where that could come from ?
Thank you !
Sophie
    Hi there:-)
    As you say, VC fixed conflict with Revo Slider(i think so anyway), so it shouldn't be the problem. Maybe issue is somewhere else.
    I think I will have to take a look myself to give you some precise answer.
  • Pm sent :) Thanks
    Hi again!
    I have just tested and it seems it is still conflict of Visual Composer and Revo Slider.
    I have even tested on default WP theme: Twenty Seventeen, with only RevoSlider and VC plugins active, and still there is same issue.
    I am afraid you will have to deactivate revo slider plugin for time while you edit your site with frontend VC editor, or just use backend editor.
    contentologue said: I was allready using visual composer and revolution slider with the previous template and it was ok.
    Can you tell me what was name of that template, so I could check if they have some clever trick to make them work together.
    Form what I know, RevoSlider plugin can be active and will not affect Frontend Visual composer when Slider is not added to page that you are editing.
  • Ok, I will desactivate it, thank you. The theme I was using was TheGem. It was a horrible theme (that's why I changed), but they were providing also visual and revo in the package and also demos that I tried to modify : and it was working front end and revo in the same time with no problem.
    Just a question, btw, do you update visual and revo ?
    contentologue said: The theme I was using was TheGem
    Thanks, I will investigate it on Monday!
    contentologue said: Just a question, btw, do you update visual and revo ?
    Yes, sure. When authors of that plugins release updates to their plugin, we add them to next theme update, so don't worry :-)
  • thanks ! :)
    I have checked and theGem theme also fails when editing page with VC front editor when Revo slider is on page.
    I am working with Revo guys on this issue. For now they are not convinced to do any work, like usual when two plugins are in conflict, but I am pressing them :-)
  • Maybe I didn't use it enough long to see it. But, I could see my banner and the content in the same time and modify it on front-end. I don't know why. Maybe since the visual update ?
    Hard to tell. Anyway I got reply from Revo slider guys that they confirm that issue is real, and they will be working on it with Visual Composer guys. Hope they will find a way to solve it:-)
  • Thank you anyway ! :)
