Hi !
I have a problem with visual composer : the front end builder doesn't work, it doesn't show my slider, or background.
I was allready using visual composer and revolution slider with the previous template and it was ok.
Do you know where that could come from ?
Thank you !
Sophie
As you say, VC fixed conflict with Revo Slider(i think so anyway), so it shouldn't be the problem. Maybe issue is somewhere else.
I think I will have to take a look myself to give you some precise answer.
I have just tested and it seems it is still conflict of Visual Composer and Revo Slider.
I have even tested on default WP theme: Twenty Seventeen, with only RevoSlider and VC plugins active, and still there is same issue.
I am afraid you will have to deactivate revo slider plugin for time while you edit your site with frontend VC editor, or just use backend editor.
Can you tell me what was name of that template, so I could check if they have some clever trick to make them work together.
Form what I know, RevoSlider plugin can be active and will not affect Frontend Visual composer when Slider is not added to page that you are editing.
Just a question, btw, do you update visual and revo ?
I am working with Revo guys on this issue. For now they are not convinced to do any work, like usual when two plugins are in conflict, but I am pressing them :-)
