Ask for an urgent answer.
The "Theme options" panels are a long time banned from the themes that are sold on the ThemeForest. :-)
All of theme options are available in the WordPress Customizer -> https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/how-to-use-customizer/
Hope that helps :-)
Please reply on the forum next time :-)
I see a link to the Customizer on your screenshot from the admin panel. What happens when you click it?
With kind regards
Thanks for the access. The issue was caused by the plugin "Customify". I have deactivated it and everything works fine now.
