Elementor update from 3.1.4. to 3.2.2, Compatibility Alert
in Rife Posts: 9
I want to update Elementor from 3.1.4. to 3.2.2. but before I do this I wanted to ask you about the Compatibility Alert I get:
See file attached
Can I update Elementor or will there be any incompatiblities/troubles?
Cheers,
Clara
    If you could hold up 2, 3 more days, I will update Rife Elementor Extensions & Templates plugin as there are some notices displayed with newest Elementor.
    Not harmful, but better to remove them :-)
    Thanks for your question!
    Plugin is now updated, so you can get a new version and use it with new Elementor.
    Air.
    Thanx so much!
