Slideshow stopped working on front page...
edited January 2013 in Airlock Posts: 13
I had the slideshow working great since:
http://support.apollo13.eu/discussion/comment/1529#Comment_1529
Now, the slides aren't loading. I'm not sure what has changed.
Any ideas?
    Hello.
    I think I know what could be the issue. Try using this file http://support.apollo13.eu/discussion/comment/2798#Comment_2798 it should fix theme working with WP 3.5
  • Hmm, I uploaded jquery-ui.min.js to the js folder location.
    But Slideshow is still spinning on the front page.
    Check it out:
    http://coldfusionnow.org/
    It just happened last night. What could have changed?
    It is not just slider it is your whole page JavaScript. I see you are linking to newest jQuery available which is very wrong as old libraries depends on many things that are removed in newest version. Stick with jQuery. 1.7.x and you should be safe, and also look out for Wodpress updates.
  • I think Wordpress 3.5 has broken Airlock beyond my ability to repair it. I uploaded the right file jQuery. 1.7.2, but nothing changed.
    Can you suggest a theme that is similar? Here's the site:
    I like Airlock, but don't think I will be able to fix it. Is there a theme similar, but updated to go with the Wordpress they are using now?
    You are still using jQuery 1.9 :-) I don't know what you have installed there, but it is messing much. If you like send me temporary access to your WP and FTP so I could check there what is going on? Send it here on forum via private message.
    It shouldn't be hard to fix it :-)
  • Thank you Air.
    I sent you a message.
