Has any one been able to have another slider on homepage together with the album list?
edited January 2013 in Hypershot Posts: 39
Hi
I have everything working in my home page, with the brick view, but would like to set up a slider on top of them (like in the atached image). I have a Slider plugin that offers the posibility of inserting a shorcode or theme function. Tried both but none work. Any idea how to do it?
Gonzalo
    Inserting slider on such custom page will require some extra work and styling. I got no info if anyone tried this before.
  • Lets think it another way. Is there a way of putting a short code calling the album list into a regular page.
    edited January 2013 Posts: 10,970
    There is no such shortcode :-) Too big job for shortcode - that could make mass of conflicts that we rather would to avoid.
    Still if you are familiar with PHP and some CSS I believe you can push down div#mid(in bricks album) by inserting before it some other element(for slider) without much of conflicts.
  • Sorry no PHP expert :(
    Ill see what I can find. If I get the solution I will post it back here.
  • Air
    I did it. Still solving some issues. As soon as I make it work totally, I´ll post the solution.
    Gonzalo
  • edited January 2013 Posts: 39
    Done
    Install Soliloquy Slider and follow instructions until you create a slider. When done it will give you a php code to insert into the template. In my case I did so in albums-list.php on line51. Remember to put the code inside a <?php code that Soliloquay gives you ?>.
    <?php if ( function_exists( 'soliloquy_slider' ) ) soliloquy_slider( '1371' );?>
    Remember that the number 1371 can change case to case
    And that's it. It works OK and it even gives the possibility to make it translatable via WPML:
    I still have to solve a problem about aligment in center of page. Can you give me a hand on this?
    www.proinsus.com
    Gonzalo
    Post edited by proinsus on
    Good job;-)
    Add this custom CSS:
    .soliloquy-container{
    margin: 0 auto;
    AIR
    .flex-container { margin: 0 auto !important; }
    Adding this code did the job
  • Sorry to inform that it is not translatable :(
    I´ll try to find a way round
