Hi
I have everything working in my home page, with the brick view, but would like to set up a slider on top of them (like in the atached image). I have a Slider plugin that offers the posibility of inserting a shorcode or theme function. Tried both but none work. Any idea how to do it?
Gonzalo
Still if you are familiar with PHP and some CSS I believe you can push down
div#mid
(in bricks album) by inserting before it some other element(for slider) without much of conflicts.With regards.
Ill see what I can find. If I get the solution I will post it back here.
I did it. Still solving some issues. As soon as I make it work totally, I´ll post the solution.
Gonzalo
Install Soliloquy Slider and follow instructions until you create a slider. When done it will give you a php code to insert into the template. In my case I did so in albums-list.php on line51. Remember to put the code inside a
<?php
code that Soliloquay gives you?>
.<?php if ( function_exists( 'soliloquy_slider' ) ) soliloquy_slider( '1371' );?>
Remember that the number 1371 can change case to case
And that's it. It works OK and it even gives the possibility to make it translatable via WPML:
I still have to solve a problem about aligment in center of page. Can you give me a hand on this?
www.proinsus.com
Gonzalo
Add this custom CSS: With regards.
Adding this code did the job
I´ll try to find a way round
