Hi Team,
I really luv ur theme but i'm a french user & i've got a pb with all accents & special characters i use in my titles ... I try ISO code (like & = 3 9 ; {without spaces} for ') but it doesn't work too ...
How can i write some beautiful titles with accents ?
Many thx
Go on: http://cufon.shoqolate.com/generate/
Tu rentre ta/tes typos.
Tu précise Basic-Latin (par défaut)
Dans les caractères spéciaux, tu rentres les lettres accentuées... (éèêëâàùûô...)
Tu récupère le Cufon et le met dans le dossier /themes/airborn/common/fonts
Bien à toi Flo
Mais cela ne fonctionne tjs pas. Il me manque tjs les accents malgré le changement de cufon.
Cordialement.
Firstly apou thanks for Help ;-)
The problem you are pointing here is connected with cufon. We provide only "standard" chars too not make fonts to heavy. Downsides of this approach is that some languages will suffer with lack of special chars.
Here is link to fonts used in Airborn: http://support.apollo13.eu/uploads/airborn-fonts.zip
use it to make new cufon files following this instructions: http://www.emreakkas.com/internationalization/cufon-and-foreign-character-sets-bring-your-missing-characters-back
After place new cufon files in wp-content/themes/airborn/common/fonts on ur wordpress installation.
Please be sure to keep names of files same as they were before.
Good luck, and sorry for any inconvenience:-)
In my case, there was just missing the "Latin-1 Supplement" option ...
Now, it's done !
I do have the airlock theme (great, I like it!) and the same problem. In your post you provide a link to download the font package for airborn (http://support.apollo13.eu/uploads/airborn-fonts.zip). Where can I find the package for airlock?
here is such topic for Airlock http://support.apollo13.eu/discussion/comment/369#Comment_369 :-) Soon Daniel will add zip file with fonts.
Both fonts are attached to zip that you downloaded from ThemeForest.
Look for "Fonts" folder
Best Daniel
