Post options appear while editing post in classic way, not using Elementor or any other page builder. You should see them at bottom of the edit screen. See this screenshot:
Yes, I'm in classic editor, but on this options, I can't make the post without any sidebar (if I choose "header" tab, and set sidebar as "off", nothing happens.
But it's ok, I will make my post a page instead. If you have any idea though, I'm interested.
Thank you !
Sophie
To disable sidebar in posts go to Customizing ▸ Blog settings ▸Single post ▸Sidebar.
The option that you were tried to change is for vertical header, that you are not using ;-)
There is no option to do it from theme options.
However, with this code, you can do it from a child theme.
Add this to functions.php in the child theme, at end of the file You can edit IDs in
$ids_to_exclude = array('6670', '6671', '660');
and enter IDs of posts you want to not have sidebar.I hope that helps.
